How can I control my part and sketch dimensions from an assembly configuration?
joshtargojoshtargo Member Posts: 461 EDU
I want to make a geometrically simpler MAXTube for assemblies where it has sketches for hole placements rather than hundreds of actual holes.
How do I set up a configuration variable that affects the part and sketches at the same time?
Currently the sketches are based on the part size by being drawn on its faces.
When I change the part size in the assembly, the sketches don't update.
https://cad.onshape.com/documents/fedda7d876a3272f4cf37980/w/f482e6ab5578bc0f10886eb5/e/228563a72506b4a23af724b9?configuration=default&renderMode=0&uiState=671fb0af6fd9557cc31e5d29
