Properties Window vs Heads-Up-Display
Would you rather have a properties window that opens when a particular tool is selected (like offset and pattern) to define the variables....or stick with altering the variables on the current heads-up display?
I find that with the current framework, I have to move the variables around so I can read them because they are overlaying on other entities.
Take for example this screenshot. I am using the offset command.
