Need help removing a section
nelson_pereira280
Member Posts: 37 ✭
in General
For some reason, I cant seem to be able to remove that section when doing an extrude. It keeps that small wall there.
link to file: https://cad.onshape.com/documents/87deece7ee7fdb9ded0b46fa/w/d4a3e9b1395cfa18176724a7/e/0f311288802dff457dbeffa5?renderMode=0&uiState=67212f29e2fcca1cf47b2587
Can't see exactly what's going on without ability to copy your doc. but it looks like you used Plane 5 for your sketch and that front face is not perpendicular to plane 5. You can do another extrude to finish off, or you might try delete face tool.
the issues is:
Sketch2 is not constrained it needs Horizontal - and Vertical | constraints.
and then fix sketch 3 to suit. and you will get the outcome you require
