Can I get all of the points where a curve passes through a plane
EvDistance only seems to return one intersection point, even if a curves passes through a plane multiple times. How do I get them all?
  • You can copy that curve, split it with plane, and evaluate vertices which are created by that split operation
  • As @Konst_Sh said that will work but the qCreatedBy(id,EntityType.VERTEX) will not get the start and end points also if they were not split so check the original vertices to see if they touch the plane using either evDistance or distance check between the point and the return of project(plane,point)
