Pattern following a curve
Hey folks,
Trying to wrap my head around linear vs part pattern to reach my end goal and cant seem to spot what im missing. I am designing a simple girder bridge that bows in the middle.
I have my two curves fully defined and all is good there, so looking to do the cross members by patterning as opposed to doing each individually. This is the design im making, so simple enough of a repeating pattern at 45 degrees
This is very much a "Spirit not replication" kind of model so specifics are not hugely important in terms of detail, just the general shape.
When trying to use a linear pattern it wont work because of what it says on the tin, linear. So I created a 2nd sketch of just the cross member to use part/feature pattern to follow the curve and cant seem to get that working either because if the extrude part is added to the first part its no longer unique, and if it its a seperate part is does not connect correctly to the lower curve even though the parts are coincident on the sketch
Would one of you kind souls please highlight the error of my ways?
https://cad.onshape.com/documents/c2c4394092d1016599819f34/w/8a9d238eb990f0143761e7f9/e/5ac6fc80630a02ca63d86e84?renderMode=0&uiState=6724c4d770123d4c26be5eb7
