Project solids edges into angled planes
paulo_costa276
Member Posts: 6 ✭
in General
Hi, I want to project some edges from a solid into an angled plane, but the Use command just projects the edges in the same direction as the angled plane and not from the direction from a determined plane.
As an example, on the picture, I would like to have the solid cylinder horizontal edge line, projected as a horizontal line in the angled plane. Is there a way to select the projection plane direction?
Project curve to surface.
Thanks @S1mon! 👍️ It does solve nicely.
