Spitting a part
I am trying to split this part into four segments so i can upscale it for 3d printing. this is the maximum size i can go with my printer so i thought i could print the parts separate and the bolt them together after i have re scaled them.
Any help on how to do this would be much appreciated.
https://cad.onshape.com/documents/3439ac8e03697ca6f4a6f63b/w/86db3064b74f2ce574d41fe9/e/7c6eb2ec5eb736a7e5aacc14
  • robert_scott_jr_robert_scott_jr_ Member Posts: 736 ✭✭✭
    edited November 2024
    Hey Tim. Filament or resin? What's it for to get an idea of how strong it has to be. - Scotty
    Something like this may work but I think it would lack any robustness. It's already a thin piece that lacks that unless used in a lightweight manor. A resin printer could provide the detail of the dovetails but I would not attempt this with a filament printer. And with a resin printer, applying resin to the joints and then recuring could be used to rejoin the 4 parts. - Scotty
  • martin_kopplowmartin_kopplow Member Posts: 1,173 PRO
    Cut in four quarters where the spokes are, discard 3 of them. Create one quarter with wavy cut faces to increase glue contact surface, then print that four times, glue together. I've done that countless times, worked every time.
    (Hint: Use 3D-waves to facilitate exact positioning, use a negative offset of 0,1 to 0,2mm per side, depending on printer. Print the parts with support structure and only remove the support after parts are joined and glue has cured!)
  • tim_hutchinson779tim_hutchinson779 Member Posts: 7
    Thanks for the feed back.
    I'm using filament and the model is for a base plate that will hold my camera and long lens when i am laying flat on the beach to photograph birds. i have printed it to the maximum size on my printer (Prusa) and it works OK except i think it needs to be larger for more stability in use. I hope that helps.
    Have you checked the link to a copy of your document that I made changes to? A filament printer doesn't have the ability to print what I showed as a possibility. A lot of tolerances would have to be built into the model for it to fit together. Perhaps print attachable legs and modify your current model to accept them. - Scotty
    Hi Scotty, yes i did and i like the idea, i think i may have to redesign it with some of your suggestions. thanks for your help.
