PLease HeLp: cant fillet
emma_bolesemma_boles Member Posts: 2
i cant seem to fix this issue. if you look at the images provided below, the fillet function is being strange. it seems like onshape is registering the shape weirdly. in the first one, it is all one part but in the second, I extruded the details so that they were all separated parts. can someone please help me with this? I've tried so hard to fix it and I just can't figure out a way :(.
  • MDesignMDesign Member Posts: 1,282 PRO
    You'll have to provide a link to your doc for further inspection.
  • martin_kopplowmartin_kopplow Member Posts: 1,163 PRO
    This is usually a hint that the shape in the figure's crotch is not tangent after mirroring. Try making it so that the curve ends horizontally in the sketch. Then it'll be tangent after mirroir.
