thread M80
Prof_Pablo_LangProf_Pablo_Lang Member Posts: 5 EDU
I am a professor at the university and I am teaching ONSHAPE.
How do I make an M80 threaded drill in CAD?
Thanks
Pablo
  • MDesignMDesign Member Posts: 1,284 PRO
    Make a hole the OD of the threads. Use the ThreadLab featurescript to create modeled threads plugging in the thread information.
  • Prof_Pablo_LangProf_Pablo_Lang Member Posts: 5 EDU
    Hola
    Me interesa el modo "blank", pero no veo en el plano las lineas que representan a las roscas?
    Me ayudan ?
    Gracias
    If your goal is the large hole example use the hole feature and show hidden lines in the view you want to see threads. if your goal is the small hole example add the use of threadlab modeled threads to the hole.
  • aris_setyawanaris_setyawan Member Posts: 10 EDU
    Maybe this can help you, I am using the thread creator feature script, here is the document link.https://cad.onshape.com/documents/1118a5fe0468a0aa6231f559/v/1c2c601b115649aa8f134358/e/bab316fc7cbdbe184e25ad85
