Trying a loft, no success
hansrudolfhansrudolf Member Posts: 55 ✭✭
It looks so easy in that video in the help section. I have a circle in the first plane, ans an ellipse in the second plane a certain distance away. But a loft between these two curves always fails. I'm lost, didn't think that still happens after umpteen years with Onshape.
Kind regards,
Hans
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 369 image
    what’s the error message you are getting?
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 561 ✭✭✭
    Try some tutorials before complaning. from a circle to a elips you need 4 guiding lines.
    When your smart and you do half a circle and half a elips you need 2 guidelines
