Need help cutting shape into a solid
I am new to onshape and I am stuck at lofting and then cutting a solid with the lofting surface. Could someone help me?
Link: https://cad.onshape.com/documents/1f9a007444d1873865733d60/w/fe2797087b6caafe201c4ab3/e/78c6acaf5da02a142cfae21a
  • GWS50GWS50 Member Posts: 498 PRO
    Either your document is not Public or your link is incorrect.
    If you right click the document on the document page (Home Page) and select "Make Public" we should be able to see it
  • robert_scott_jr_robert_scott_jr_ Member Posts: 743 ✭✭✭
    Hello Kris. I used Loft/Remove. Is that what you are after? Document- Scotty
