Camera placement in a specific point inside the model
eli_feigineli_feigin Member Posts: 2 PRO
Hello
I am doing a viewing angles analysis and I would like to use onshape for this purpose. I am looking to afeature similar to solidworks where I can place a camera on a specific point inside the model, define its pose and lens properties and get the view of what does the camera sees.
The equivalent feature in solidworks is the following:
How to do the same action in onshape?
  • S1monS1mon Member Posts: 4,061 PRO
    There's no direct function to do this in regular Onshape. You can use perspective mode and move around to get somewhat where you want to be. If you have RenderStudio (Pro or Enterprise) then you can control camera location.
