Distorted Loft
graham_lockgraham_lock Member Posts: 265 PRO
Hi,
Referencing the image below:
You can see a simple loft, all sketch regions are of the same diameter.
There is distortion along its length.
What would be the best way to overcome this? I don't have any geometry to setup guides or paths? Or do I??
Thank you.
  • martin_kopplowmartin_kopplow Member Posts: 1,288 PRO
    Use guides and connections to eliminate the twist and distortion. One connection usually already does the job with simple geometry.
  • graham_lockgraham_lock Member Posts: 265 PRO
    Thank you - connections did the trick!
