Joining of parts
in Drawings
I have an element made of two parts. When I print it, it falls apart, it doesn't stick together. How can I draw it so that it sticks together so that it's just one part.
https://cad.onshape.com/documents/a2934fa92b888cd6cc8e90d8/w/a24c1b6f4537ad01bc9ca5e7/e/39e372348ecad1644a2eef24?renderMode=0&uiState=673f982ce9248657d1978f70
The quick way would be to modify Extrude 2, so you have one part rather than two:
https://cad.onshape.com/documents/c26042a4ac95e8be387f7b26/w/96ac6d554e24a4e7a63cce92/e/1e5320134c6152d9804a93b1
You could also use surfaces to make everything nice and clean:
https://cad.onshape.com/documents/c26042a4ac95e8be387f7b26/w/96ac6d554e24a4e7a63cce92/e/eb762d344fe8bf00b866da68
The first extrude is done with a draft angle that creates a none manifold condition when the second extrude is set as add.
In other words the parts do not overlap or at least come face to face. There is probably a better way but for the sake of expediency I drew some extra curves in sketch one so that selections for second extrude overlap part 2.
https://cad.onshape.com/documents/e1b8901f5adf0de3a28e55aa/w/fd3fed304f304e451af2016b/e/98a89cee54d0191ff1ba5f4f
