Query filter help for vertices?
S1mon
S1mon Member Posts: 4,615 PRO
I'm trying to construct a query filter which will take individual vertices, edge points, mate connectors, and/or whole sketches. When I select a whole sketch I want it to use any sketch points, or vertices of sketched lines/arc/etc, but not from construction sketch entities. I don't really understand "ConstructionObject.NO" since that doesn't seem to remove construction entities from sketch selections.
  • Caden_Armstrong
    Caden_Armstrong Member Posts: 471 PRO
    edited November 2024
    Vertices themselves aren't marked as construction, but edges are.
    You could take all of the vertices, find all vertex adjacent edges.
    And then find all that are construction edges.
    And then take all of the vertices adjacent to construction edges,
    and subtract from your original query.
    Where seed is a query of vertices
    and then take this query and subtract it from your original query to remove all the construction vertices.
    var constructionRemoved = qSubtraction(seed, qAdjacent(qConstructionFilter(qAdjacent(seed, AdjacencyType.VERTEX, EntityType.EDGE), ConstructionObject.YES), AdjacencyType.VERTEX, EntityType.VERTEX));
