Editing an Extrusion
william_turley
Member Posts: 9 ✭
Does anyone know the best method to make the middle section (9mm)
of this a regular rod while leaving just the ends (3mm on each side) cut?
nick_papageorge_dayjob
Member, csevp Posts: 1,038 PRO
On your first extrude, pick both regions of the sketch, to make a complete circle extrusion.
Now, unhide the sketch (the extrude command will hide it).
Now make a second extrude, only picking the slot portion of the sketch, and make it a 3mm long cut. On the right end of the part, do the same thing, but pick the right face as the starting offset inside the extrude command.
1
Thank you this worked
