Please help me finish this
akil_prabhakar
Member Posts: 17 ✭
There is a cylinder inside which are 3 surfaces, can anyone help me fill the gap between the surface and cylinder and please help me remove the part of surface 2 that is protruding outside the cylinder and please let me know how you got it done. Thank You
Note: the model is very small just 3.6 mm maximum width
https://cad.onshape.com/documents/a84e021a0c52f0eb3581fc92/w/e964a2324494cbfc44a4c1a8/e/0840108afd73f31b2abef646?renderMode=0&uiState=674cb425c85ddd597d5cc193
What is that you are trying to make? - Scotty
here you go… but it is a mess. there are better ways to design this, maybe you should invest some time in surface technics. Onshape tutorials are pretty good.
https://cad.onshape.com/documents/73d06d1773b92f4b5cb8eb9d/w/698eaa9d0352ef4906c5d3c5/e/b29074094467ae43a2b259e9?renderMode=0&tangentEdgeStyle=1&uiState=674de17a04365b7f71c6955f
@robert_scott_jr_ just learning onshape and I'm a newbie.
@rafael_telgmann thanks buddy, I'm new to this CDA process, have tried onshape tutorial but i think i need to learn more, can you suggest from where I can do that.
