Please help me make a design in OnShape
can you make me me a box that have a net? like for example a basketball net but its box or square… I been searching on how to create a net but it doesnt show up please help,,,
  • robert_scott_jr_robert_scott_jr_ Member Posts: 737 ✭✭✭
    I came up with quite a few forum posts on the subject of nets when using the keywords Onshape net in an online search. Try that. - Scotty
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,046 PRO
    One simple method:
    Make a box. Shell it to be hollow, leaving 4, 5, or 6 sides deepening on your end goal.
    Make a square cut the size of the net "opening". Pattern it. Do some math to figure out the opening size, number of patterns, and the space between the patterns. That will result in the web thickness left between the openings.
    The end result should look pretty good.
