Assembly not updating after changes made in parts studio within same document.
stan_howestan_howe Member Posts: 4
edited December 2024 in General
I created several parts studio's , one is quite complex with multiple parts, drawn in situ. I then added the parts studios to an assembly studio within the same document. For the multipart, complex part studio, I imported all parts at once and Grouped them to maintain thier relationship to each other. I am also creating drawings from the assembly studio. I discovered some errors and went back to the main parts studio and made several changes, including making new parts. These changes were not reflected in the assembly(at least the new parts do not appear). I tried to create a revision of the parts studio, but the blue update circle in the assembly is not active.
Is there an easy way to update this parts assembly, or do i have to insert each new part individually and fasten them in the assembly?
update:
NEVER MIND. I inserted and fastened each new part. it wasn't as bad as i thought.it would be.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,509 PRO
    Also if all the parts from one part studio are not moving relative to each other, you can use the "insert as rigid" option and then any new parts from that part studio will be added automatically.
