Why is inserting a view of a configured assembly instance into a drawing not possible?
StephenGStephenG Member Posts: 383 ✭✭✭
I have created a configured assembly for a piano hinge that needs a drawing to show how it is derived (cut from) from a vendor purchased piano hinge.
The "Insert view" function will only allow selections of part/assemblies from document tabs; an instance of the configured assembly is not supported.
The only way I found to create views of the configured assy instance is to create a view of the parent assembly an hide all the other parts except the piano hinge parts. This is very cumbersome because parts must be selected one at a time; I cannot select parts by area selection.
I also tried moving the instance into a new subassy, but this messes up the assy mates that define the mechanism behavior.
Is there a "clever way" to accomplish create a drawing of a configured assembly instance?
  • mfalkensteinermfalkensteiner Member, Onshape Employees, csevp Posts: 87 image
    Hi StephenG,
    If you have set up configurations, you should get an insert view dialogue like this. Could you share what you see?
    Principal Technical Services Engineer, EMEAI
  • StephenGStephenG Member Posts: 383 ✭✭✭
    Yes, it is possible to create a drawing view from the Assembly tab that defines a configured assembly, but the config state in the assembly tab is not the configuration state when instanced into another assembly.
    If I change the configuration of the assembly instance I want a drawing view of it to reflect the configuration change. This is why it makes sense to support creating a drawing view of an assembly instance. The same should also hold true for instanced parts with configurations.
    Each tab has its configuration. This means that if a configured part is inserted in an assembly and this installed part is also to be configured, a configuration must be created in the assembly tab.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,499 PRO
    A "phantom" sub-assembly should work…
    Moving the hinge to a sub-assy should not mess up the mates.
    It would be nice to have a way to do this "natively" as it can be tricky to make sure you are using the correct configuration on a drawing.
    edited December 2024
    Creating a "phantom" assembly (Move to new subassembly) of the configured assembly instance works around the inability to create a drawing view directly of a configured assembly instance. It certainly is a lot easier than creating a view of the parent assembly and hiding all the parts except those that make up the configured assembly instance.
    I was able to create the drawing that describes how to derive the hinge from off-the-shelf hardware.
    However, this method does come with some complications:
    o The parent assembly structure gets an additional layer that doesn't make sense. An assembly instance that contains just one instance of an assembly.
    o Any additional constraints that were added in the parent assembly to further restrict motion within the parent assembly, along with named positions are not copied into the subassembly.
    o You have to switch to the "phantom" assembly to change the configuration of the configured assembly instance.
    The above issues would be non-issues if OS had better part selection methods for hiding parts in a drawing view, or allowed selection of configured assembly instances when creating drawing views.
