Help - Why does not this extrusion work?
tomas_hellströmtomas_hellström Member Posts: 4
Hi!
I am struggling with the following extrusion. fi want the base face extrude to the face of the other part that is a cylinder. I need some direction how to fix this. Thanks in advance for any type of input.
  • EvanReeseEvanReese Member, Mentor Posts: 2,865 PRO
    it looks like it's tangent to the cylinder, which makes it impossible to merge with it. Either make them overlap, or change the feature to New instead of Add.
  • tomas_hellströmtomas_hellström Member Posts: 4
    Thanks for your input. I actually managed to solve it by extruding it both ways. Into itself with 0.1 mm and to face. Then I could use the Add option. Not sure why that worked but might have to do with your suggestion.
