I made a configurable M4 Nut/Bolt/Washer assembly
joshtargojoshtargo Member Posts: 495 EDU
FTC robots use M4 fasteners almost exclusively, and besides the fact that Onshape doesn't have Nyloc nuts built-in, I wanted to be able to also include different washers.
Once Inserted into an assembly, it can be copied and reconfigured as-needed.
Washer is Fastened to the head, but the nut is on a Slider
Link: Configurable M4 Nut/Bolt/Washer
https://cad.onshape.com/documents/53e8919fcb98789bd175cf0b/w/883ddacc54f751275a9ab1b1/e/710efdc3f841181947ea5eae
