Help with Lamp Assembly Please!
justin_chen618
Member Posts: 2 EDU
Hey,
Anyone mind helping me assemble this? The pin fits into the other small, blue component, which goes under the lamp head. It all attaches onto the lamp stand. It's much appreciated. I'm not familiar with the assembly process at all.
Just a brother trying to finish his college final.
Thanks!
Besides you actually should do this yourself if you want to really earn your college final, you'll also have to do this all by yourself unless you share the file with those who could help. ;0)
Read up about mates and connectors.
Good learning resources here:
https://learn.onshape.com/
Do a search for assemblies. You'll put it together quick enough! You probably need to think how to get that I shaped part through the hole. Easy in CAD, not so much with actual physical parts.
They are teaching you Onshape in college?
