opHole Examples
RhettRobinson
RhettRobinson Member Posts: 250 ✭✭✭✭
I thought that incorporating a hole feature within a FeatureScript I am writing would be more helpful than the same size hole extruded and cut since I want the end result to be a tapped hole. The value will always be the same since this is for a company standard. I went to the Standard Library Documentation and was almost more confused by trying to figure out what parameters are needed. Are there any good examples floating around for this?
  • EvanReese
    edited December 2024
    What you might do instead is just call the actual hole() feature. I think the attributes aren't added to the faces via opHole anyway. You'd want to import the hole feature studio into your custom feature, then you can call hole(context, id, definition);. Look at the precondition code (the UI part) for the hole feature to understand what all of the keys are on the feature definition. Then your custom feature can create a definition to feed the hole function. The result will be equivalent to using the native hole feature, but your feature can be the one controlling the inputs instead of the user's input. If that all sounds as confusing as I imagine it does hit me up with questions, haha!
