How to check why a regeneration failed?
w_s856w_s856 Member Posts: 58
Following the advice of @jelte_steur814 in a previous question, I tried to create a face linear pattern. It almost works - almost because the resulting element is red and there is a "not regenerated properly" error message.
My guess is that I missed a face to make the new piece whole — is there a way to get more information about the "why" of the message? ("regeneration failed because the object is not whole, the face XXX is missing" ← the last part is too much, but any kind of information would be helpful)
There are already many similar questions so I guess that the answer is "you need to click-n-try" but maybe not?
Specifically in my case (https://cad.onshape.com/documents/d7aebcbf751ea63aa06fa480/w/d496255ea19f9425bb0ebe6c/e/1fe3d10623afa6ca25027db7?renderMode=0&uiState=675afaaf89db9f7b40a035a8) the image was
  • w_s856w_s856 Member Posts: 58
    I solved my problem by selecting ("in a rectangle") the whole piece and it regenerated fine. I am curious about the general question, though.
  • jelte_steur_infojelte_steur_info Member Posts: 648 PRO
    edited December 2024
    Going by your solution that indeed means one small face somewhere was not selected like the chamfer, or the end face of the sweep.
    box selecting is generally recommended indeed.
    you got that already.
    i don't believe there's more information available elsewhere than the error you mentioned.
    If you change a lot (fillets etc) on such a boss upstream, you'll have to reselect the faces all the time for the pattern to keep working. this may be cumbersome. a part pattern or my custom 'regional pattern' would work better then.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,550 PRO
    @w_s856
    A way to "sidestep" this entire issue is to keep the "blocks" you want to pattern as a separate body (i.e. separate part) and use a part pattern.
    This will be more robust than a face pattern, especially when the pattern involves a number of faces like this.
