Help needed - Can't seem to do what I want to....
Simon_JamesSimon_James Member Posts: 4
I am trying to draw a cyliner with holes cut through it - imagine a cylndrical lamp shade or a muzzle break or something like that.
I have drawn a cylinder, shelled it out, added a plane, drawn on the shapes that I want and then managed to get it to wrap around the cylinder - can only seen to add material and not take it away.
I am new to onshape, so any help would be appreciated.
screenshot attached.
thanks Simon
  • MDesignMDesign Member Posts: 1,306 PRO
    edited December 2024
    Have you tried the move face tool?
    You should be able to just set the wrap to remove material instead of add it.
    Also check out this icon if you are new and really want to dive into tool capabilities.
