Deep negative imprint like in plasticine
antun_rosovicantun_rosovic Member Posts: 9
I have many parts I want to make a (3d printed) box for.
I want them to be fixed inside. One way to achieve this is to make negative shapes (like molds) for them in the box and in its lid.
My question is:
How to make imprint of part A (imported STL) in part B, with a desired depth?
So, the bottom of the imprint would be the same shape as underside of part A, and "tunnel" to this bottom through part B to be the silhouette of the cavern made by part A..
Subtract in Boolean woud be ok to make the part A's shape cavern in part B, but - what then? How to create the tunnel? Is it possible to poject the cavern (part A is STL!) to the top of the part B? And how to extrude the projected sketch to the bottom surface of the cavern (generated by STL substraction) but no more?
Thx in advance
  • MDesignMDesign Member Posts: 1,292 PRO
    Really difficult to follow what your trying to accomplish. Do you have any visual aids?
  • EvanReeseEvanReese Member, Mentor Posts: 2,825 PRO
    There's a custom feature called Project Body that is useful for this. It can basically cast the "shadow" of a part, which you can then use as an extrusion profile. I worked up an example here. Now what I'm not sure of is whether Project Body will work on an stl, but I kind of doubt it
