Trouble with loft not lofting
jeremy_ogburnjeremy_ogburn Member Posts: 6
Hello, I am trying to loft between two of my sketches. I am not sure why it is not rendering properly, see below:
This is the link to my project:
https://cad.onshape.com/documents/121a50687642ee8758d957e/w/a14bfc4f91c72b7d1a623370/e/502573087d47b4d3da62c80c
I'm trying to loft between "outlet" and "outline"
  • jelte_steur_infojelte_steur_info Member Posts: 653 PRO
    if you check "connections" you'll see more of what it's trying to do. (and how that's not going to make proper geometry.)
    you can even match connections and get it working (I doupt whether this what you're trying to achieve):
    but it would be better to keep you outline as simple and clean as possible, and add details further down the model like this (see V2)
    (I have no idea what shape you're trying to achieve, I'm just guessing here).
  • jeremy_ogburnjeremy_ogburn Member Posts: 6
    Thank you!
