Propeller splitting blades from hub of step import.
stan_woodmanstan_woodman Member Posts: 5
How can I split the blades from the hub? I want to remove 2
such that its a 2 blade propeller. Its a step file imported.
Here is a shared onshape link. https://cad.onshape.com/documents/9b6d5c3ad46c8f4c675165af/w/f2f84869a524c84172434650/e/729f795cb0a063a88c9c50a5
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 385 image
    Just delete the faces of three of the blades, using the Heal option. Now do a Face pattern of the faces of the remaining blade. You can make the number of instances be driven by a variable, for parametric fun.
    https://cad.onshape.com/documents/2188756b994666f3c6913864/w/85fc20449d5ad7a9508121e7/e/56e6a8171c82062d6814024a
  • stan_woodmanstan_woodman Member Posts: 5
    Thankyou!
