why is this hole going the wrong way?
Christopher_Moutoulas
Member Posts: 40 PRO
in General
eric_pesty
Member, pcbaevp Posts: 2,590 PRO
If you use a sketch point, the hole will always be normal to the sketch plane...
You can select a mate connector on that line in the sketch instead and the hole will be a long the mate connector Z axis
1 -
MDesign
Member Posts: 1,329 PRO
I mentioned this in your other thread. it depends on the sketch in which you are referencing.
1
