Fix geometry for revolute mate
Chris_BazeChris_Baze Member Posts: 3
I'm trying to set up the attached robotic arm file, but it seems that one of the pieces is not a perfect plane where it should connect. This is preventing me from putting a revolute mate in the correct location. Could I get some guidance in fixing the geometry so that I can make the connections in this robotic arm work properly?
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 913 PRO
    Yeah, this face wasn't flat, so it wasn't possible to grab a good mate connector for the revolute.
    One quick fix was to delete that face, create a plane, and then use Enclose to re-create the part.
    https://cad.onshape.com/documents/7b265f9547ea96d0c8af0858/w/a086dde488156e48d7b16a86/e/573c41d59d964a2f802bed42
