Animation (with/without) feature script in Part Studio
Kustaa_1
Member Posts: 7 ✭✭
I've created a model of non trivial linkage (Walschaert motion in a steam locomotive). in a Part Studio.
I have a single variable (driven wheel rotation angle) that makes the linkage go through motions nicely.
I tried to do the same in Assembly but never got it to work. Perhaps the solver in assembly is not as capable as in the Part Studio, anyway I gave up, it was very painful to set up and never got it to work.
So my question is can I use a Feature Script with timer or something to animate it in Part Studio?
I realise it might kind of slow but for my purposes I could do a screen capture and edit the resulting video for the speed I want.
I have used a quick API script to change mate positions and grab screen shots to create complex animations before.
Thanks Matt, can you point me to an example if you have one?
Here is a script that grabs images using Python. I think it uses named views and the shadedviews endpoint. Other endpoints could be used to update assembly mates rather than using named views. And you could also just do a screen recording if you don't want to use the shadedviews endpoint. But I think this script could get you started.
https://github.com/PTC-Education/PTC-API-Playground/blob/main/Onshape_Animation_GIF_Generator.ipynb
