How to edit a three-point curve that is part of a part
jan_didden
jan_didden Member Posts: 12 ✭
I have a 3D part whose sides are an arc that is part of a circle. They were drawn by setting the two end points and then completing the shape, via the 3-point arc tool. Now I need to change the curvature of the arc but keep the endpoints (increase the diameter of the underlying circle). How do I do that? I tried the Edit Curve command but that doesn't work. I cannot just change the value of the diameter dimension because it is a derived dimension, not a defining dimension. I thought I could just pick the arc center point and move it up or down to change the curvature but I can't find a way to do that, maybe it cannot be done that way. Any ideas?
Jan
  • MDesign
    sounds like you need to investigate the constraints that are on your arc that might be limiting the behavior you’re looking for. Maybe a screenshot or document link might allow someone to help narrow down the issue..
  • MDesign
  • jan_didden
    It is the rightmost 19mm dimension that controls the arc curvature. The reason it didn't work initially is that elsewhere I had simensioned the arc with the radius of a circle which made that 19mm a dependent dimesion. When I deleted those other dimensions (which were only added for documentation purposes) it all fell into place.
    Jan
