resolved
Christopher_MoutoulasChristopher_Moutoulas Member Posts: 40 PRO
edited January 2025 in Using Onshape
  • tabetha_bulnestabetha_bulnes Member, Developers, HON-TS Posts: 37 PRO
    What you have selected are edges. If you want to extrude edges to create a surface perpendicular to the face you will need to select "Surface" at the top of the UI where it reads "Solid | Surface | Thin " .
    If you want extrude the face then you need to select the face not the edges.
