Apologies - Another non-manifold conundrum
dave_woodward078
Member Posts: 12 ✭
in Drawings
I'm trying to use boolean union to join a flat perforated disc to a set of ribs defined by a circular pattern. The problem I have is that the boolean fails on one of the ribs. I could understand it if all failed on all of them, but only one is failing. Any thoughts?
Hey @dave_woodward078,
Can you share a link to your document so that people can have a look what is actually happening? Looking at your picture I think the issue will be that rib is aligning exactly with one of the holes underneath.
It appears that your rib is the identical thickness of the your slot width and just happens to line up perfectly with that slot.It is odd that its not flagging it on the opposing side though. with a link to your doc we could figure it out.
Hi @MDesign and @David_YL_Nguyen. I think you are both correct and just changing the width of the fins or the holes does resolve the problem. What confuses me is why this isn't evident on all the holes on that fin and the opposite fin, or indeed on all of the fins where they cross over the holes. Link to offending part attached where you will see the Boolean fail. Thanks
https://cad.onshape.com/documents/27ea79f93fabdf91bd611e5e/w/268aa47d634f543cb1e9b08e/e/ddf0150f553db458f2a9f417
Looks like you trashed it. I get this when using your link
it will usually show only the first issue that occurs. it you solve that locally, the next one will show up.
