Flat pattern showing as different parts
barry_chisholmbarry_chisholm Member Posts: 3 ✭✭
Hi, I have created a sheet metal part. For some reason, it shows the sheet metal as 5 different parts. When I go to the drawing to show the full flat pattern I have 5 different parts. Why is it not showing as one? Any help would be appreciated.
    Did you select all the bend edges?
    There is another location that may be a problem. Two edges are connected which tries to make over lapping bends which will fail.
