sketch won't form closed profile
joshtargojoshtargo Member Posts: 495 EDU
https://cad.onshape.com/documents/c0b5a7127fd24993e8f9a3c3/w/9538eed7e8b82594df7bd72c/e/a9de429af75805e594727a92
I even rebuilt the outer rectangle from scratch and it still won't form a closed profile
Inspector shows no red on outside edges
Then I start turning the internal edges (the ones near the upper left under the "0.201") with red dots into Construction Lines and all of a sudden it becomes a closed profile!. Why would internal Loose Ends break a shape?
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 942 PRO
    Looks like you fixed it?
  • joshtargojoshtargo Member Posts: 495 EDU
    @Matt_Shields yes, but read my post:
    Inspector shows no red on outside edges. Then I start turning the internal edges (the ones near the upper left under the "0.201") with red dots into Construction Lines and all of a sudden it becomes a closed profile!. Why would internal Loose Ends break a shape?
