New to onshape. How do I fillet an inside corner of an STL mesh file.
I'm trying to edit this STL I built in thingiverse. The part where the double helix connects to the base is too weak and easily breaks after printing. I'd like to reinforce that by creating a rounded fillet. I'm able to import the file into Onshape but when I try to use the fillet tool nothing happens. I'm sure I'm missing 20 steps between but have no idea where to start. Was hoping this would be a simple operation.
  • MDesign
    how new are you to Onshape? Or cad n general?
  • brad_millson
    brad_millson Member Posts: 4 ✭
    Im brand new to onshape. My experience with Cad is mostly using tinkercad. Have tried other cads before but got nowhere due to learning curve.
  • MDesign
    most production oriented CAD will have a significant learning curve. Edit STL adds a another level of difficulty. But the overall process to do what you want is to recreate the geometry in Onshape that you need to modify and apply the fillet. Start with learning.onshape.com
  • xy_xyz
    xy_xyz Member Posts: 2 ✭
    Actual way to do what you seem to want to do:
    Convert the model to .step or similar, then import that file instead of the .stl.
    The limitation here is Onshape not treating the imported .stl as faces, and not letting you interact with it.
    The converted geometry might still have a lot of fragmented edges and multi part faces, but Onshape seems pretty good at handling that problem (filleting/chamfering multi part edges and imperfect faces), it just wont operate if you import from .stl.
    The online converters I tried worked fine, but I wont link a specific one because I cant tell which are generally is better or worse.
  • Derek_Van_Allen_BD
    Derek_Van_Allen_BD Member Posts: 1,165 PRO
    That's alright, I'll link a specific one with some shameless self promotion: https://untessellator.com/
    Full disclosure my tool currently struggles with more freeform surfaces like the one in the OP but it works incredibly well on more typical prismatic geometry that people bring in from other software. Freeform surface patching is still in R&D and I'll be putting more effort into developing the tool the more I see people getting use out of it. Check out the gallery page for some sample cases that run essentially one-shot as well as some more difficult cases that require a little bit more painting. https://gallery.untessellator.com/
