How do I get the extrude remove to intersect with the surface?
Guillermo_J_O_Guillermo_J_O_ Member Posts: 5
I'm trying to extrude the sketch profile of sketch 13 through the surface but I can't get it to intersect. If there's any other way pls tell me
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 843 PRO
    You cannot remove a solid from a surface. Split the surface with Sketch 13 and then delete the unwanted surface(s).
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,063 ✭✭✭✭✭
    Use Extrude New and then do a separate boolean remove from the surface.
    IR for AS/NZS 1100
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 367 image
    Make your solid extrude part first, then Boolean subtract it from the surface part.
