Split mesh with plane failed
aaron_evermanaaron_everman Member Posts: 11
Hi Everyone,
I tried to split a 3d scan mesh into several pieces. I used several offset parallel planes I created in Onshape as the split tools. The first split command worked good. Then I tried to split one of the pieces again with the next offset plane. But this time the split failed. Any tips for me?
