Offset part axis to face
findlay_fullerfindlay_fuller Member Posts: 4
Im trying to do a relatively simple (or so i thought) mate from an axis of a cyclindrical rolling part to a runner. I'm going mad trying to get this to mate correctly, as there doesn't seem to be an obvious way to get an axis offset from a face. I have also tried the tangent tool but it's not giving me what I'm after. Does anyone know what I should be using? I am planning to use either pin slot or rack and pinion mates after I have the basic mates defined
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 853 PRO
    If you share your document, that would help the investigation. But, if I understand your goal, I think a slider mate with some offsets will get you there.
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 182 image
    Hey @findlay_fuller,
    Try one of the edges and a circular face for your tangent mate. If you share the document would be easier to look for a solution. Thanks
  • findlay_fullerfindlay_fuller Member Posts: 4
    Hi both,
    thanks for helping out, this is my first time using the forum so im not totally sure whether the link works, but give this a go:
    https://cad.onshape.com/documents/ad8b71778aff73f0abdd603d/w/c47289b35cc98407d18995e3/e/e1e886d8b4e659337f4663e5
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,478 PRO
    I would suggest you do the training in the learning center.
    In the vast majority of cases you should only need a single mate between two parts, i.e. the planar mate is rarely used and all you between the two rail pieces is a single fasten mate instead of 3 planar (it will be much easier to troubleshoot down the road)
