Help Cleaning up edges of an assembly
kevin_duong373
Member Posts: 5 ✭
Hello, I am struggling to figure a way to clean the edges of this assembly. The extra edges that you can see off this object is due to an imported obj. I added in.
Fairly new to 3d modeling so i thought importing would be the most sufficient method for parts i don't know how to make but it's actually significantly difficult.
https://cad.onshape.com/documents/d1f10d8970b9f760744c744c/w/115951221d07bb79ba9099ab/e/2841a7da0739088d13a392d4?renderMode=0&uiState=67946bfc52b2dd03ea504f48
MDesign
Member Posts: 1,297 PRO
used derived to import it to an part studio then modify it with tools like transform, split, composite, pattern. etc.
1
You cannot do feature edits in Assembly mode. They must be done in part mode. You can learn more here learn.onshape.com
how do you modify and edit an imported part?
Hello, i've gotten to the part where i have all the imported parts back in. What would be the proper way to split and delete the extruding parts from the cylinder? Also thank you very much for your patience and help!
