Remove material
ProApe
Member Posts: 219 ✭✭
Hi,
How can I remove the material above the auxiliary line, which is at an angle of 14° to the base, from both the rectangular shape and the arched shape?
I am failing with the latter shape.
Kind regards
ProApe
https://cad.onshape.com/documents/d38ee126fe34e93fd7e498bb/w/6896d3714fb03f5dd674032b/e/bf7a91ac4396b98df44e1b6a?renderMode=0&uiState=6794cf8918166a6c4119b244
I see you found an answer. Here is an other answer.
https://cad.onshape.com/documents/e54b451abaf4f02a311126f7/w/34562510429cfdfb652c1dc9/e/7b22efb7015fccef3e9f7e85
Yes, meanwhile I did find a solution by draft.
I couldn't withdraw my question because, unusually compared to all the other forums I know where every message is immediately visible to all users, it was only visible after hours.
Thank you for your solution, but I can't understand it fully because I can't find the setting for the specified angle of 14°.
Part studio1 uses a direct editing tool move face(rotate).
The angle is part of sketch 1 in part studio2.
Thank You!
Thank You!
I see you have a solution. Here's another response.
https://cad.onshape.com/documents/e54b451abaf4f02a311126f7/w/34562510429cfdfb652c1dc9/e/7b22efb7015fccef3e9f7e85 Sprunki Game
okay, that's an even better solution!
