Loft but keep one edge flat?
vanowmvanowm Member Posts: 135 ✭✭
Hello.
I'm trying to create a solid with flat bottom and curved top. All edges around should come to a point (aka no vertical walls)
So, I've created 4 sketches to define transitions for a loft:
Unfortunately, loft adds curve to the bottom when I select curved edge from "spine" drawing as path:
and if I select bottom straight line from "spine" as path. it refuses to create solid at all.
Any suggestions?
Thank you.
Test: https://cad.onshape.com/documents/0948e5c21c853ac3b01be316/w/c612bd43ec99eb407835d49d/e/cb6b3d491e48f8b83428bec8?renderMode=0&tangentEdgeStyle=1&uiState=6795df5fecbe69225db3f4c1
