Offset in sketch = extrude problem
maciekmaciek OS Professional Posts: 35 PRO
Hello,
I have a problem with a sketch. Contour is divided by offset spline, but if I move mouse over the sketch, it has a grey fill everywhere, so it means it's not divided ("inside" sketch isn't closed). As you can see, if I replace the offset spline with simple line, it works. I hope you will do something with this issue.
  • thomas_kozakthomas_kozak Member Posts: 38 ✭✭
    I've had similar problems with sketch splines and closed shapes.  A workaround I discovered is to have the spline extend past the line it's supposed to touch.  OnShape seems to handle the intersection of line/spline better than it handles the endpoint of the spline.
