Constrain queries being passed into functions
jacob_kingery
jacob_kingery Member Posts: 39 EDU
In a helper function (not a feature), is there a way to replicate the 'Filter' part of an annotation for a query parameter, like in the precondition of a feature?  I want to make sure that the query being passed in refers to geometry of a certain BodyType.
  • lana
    lana Onshape Employees Posts: 781 image
    Filter in annotation is strictly for UI use. You can  use qBodyType(inputQuery, bodyType) to filter the input
  • kevin_o_toole_1
    qBodyType will filter by bodies.
    For the other filters allowed in the parameter filter, you can use qGeometry, qEntityFilter, and qConstructionFilter.
  • jacob_kingery
    Right, but is there a way to require that the query being passed in refers to geometry of a certain BodyType?  Within the function, you could do something like this:
    export function myFunc(context is Context, q is Query)
        if (size(evaluateQuery(context, qBodyType(q, BodyType.POINT))) == 0)
            // throw error or something
    but this doesn't seem particularly elegant.  I guess it would be impossible for the code to know what the query would evaluate to without actually evaluating it, but it seems so clean when the UI just doesn't let you click on things that don't pass the filter.  It would be neat if functions could do something similar where they automatically throw an error if a query parameter doesn't pass a filter.
  • jacob_kingery
    Okay, I'll give that a try.  Thanks!
