How do I cut out the shape?
mia_briertonmia_brierton Member Posts: 2
Hay, I'm currently trying to cut out a shape but every tool I've tried wont work. If anyone one could help or give advice that would help alot?
  • MDesignMDesign Member Posts: 1,284 PRO
    try split face and delete face
    or if you're really new. try changing the extrude objection to remove. learn.onshape.com will help a lot if new
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 894 PRO
    Rather than a projected curve, try to extrude a surface and then split the original surface.
