Empty List for Derived Part?
thomas_kozakthomas_kozak Member Posts: 38 ✭✭
edited February 2016 in Using Onshape
I have a few part studios in a document and I need to use parts from those studios in a new part studio (in the same document).  From the manual the correct workflow for this is to use the Derived option as seen here.  However when I do this I get an empty list with "No entities or features available."  Is there something I could be doing wrong here?  I'd rather not have to export/import the parts in question since they need to be parametric...
Edit: Interestingly, in all other part studios in that document I can use Derived as described in the manual.
  • lanalana Onshape Employees Posts: 746 image
    @thomas_kozak
    This sounds like a bug fixed in the next release. Please share your document with support, we can fix the document so that you'll be able to move forward.
  • thomas_kozakthomas_kozak Member Posts: 38 ✭✭
    Thanks Lana.  I put in a support request and it was solved almost immediately.
