Project sketch then create a protrusion
Raym_KochRaym_Koch Member Posts: 27 ✭✭
  • Raym_KochRaym_Koch Member Posts: 27 ✭✭
    How do I get an answer to my question that is imbedded in the posted picture.
    Thanks, Erich Koch
  • Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    @ erich_koch , there are many methods to achieve your requirement,
    1. No need to do separate sketch.You can use already created sketch.Select extrude and already created sketch.Use second direction option.
    2. Select the sketch and select the face of a created body.You can project the already created sketch by using"Use" tool.
    3.If you don't want to create sketch in the face of part then you can create a sketching plane by selecting "plane" option.
    Then you can continue the second step by selecting plane instead of face.
