How to avoid weird contours in my model
luke_diep245luke_diep245 Member Posts: 10
This is designed using lofts, which creates some weird flaws that I want to avoid. The first two pictures highlight the unwanted contours.
If a better approach delivers a similar result, I would appreciate the input!
Screenshot 2025-02-02 6.54.58 PM.png Screenshot 2025-02-02 6.53.41 PM.png Screenshot 2025-02-02 6.52.49 PM.png Screenshot 2025-02-02 7.20.55 PM.png Screenshot 2025-02-02 7.20.35 PM.png Screenshot 2025-02-02 6.51.51 PM.png
  • jelte_steur_infojelte_steur_info Member Posts: 587 PRO
    can you share your document and link it here? hard to tell how to improve if we cannot review your current loft setup.
    Its likely you'r using too many contours in the loft (less control provides better surfaces quality usually).
    you probably need to model the surfaces at the nose/tip separately to model a proper transition to the sharp point.
  • luke_diep245luke_diep245 Member Posts: 10
    edited February 4
    I ended up redesigning with your advice. Problem solved, thank you!
